Rear differential leaking from fill hole after oil change?
Old Apr 14, 2020 | 03:22 PM
ski.dive's Avatar
Default Rear differential leaking from fill hole after oil change?
Rear differential leaking from fill hole after oil change=It was torqued to specs?
Old Apr 14, 2020 | 07:25 PM
wpage's Avatar
Did you ask the shop that did the work.
Sounds like it may be loose...
Old Apr 15, 2020 | 10:49 AM
It is called overfill..... which is the most common cause of all differential leaks.
Park on a level surface, remove the oil fill plug, let the excess gear lube run out while wiping with a rag. Once it stops immediately put the plug back in.
Old Apr 15, 2020 | 12:02 PM
ski.dive's Avatar
Originally Posted by Doc Olds;372318[b
]It is called overfill..... which is the most common cause of all differential leaks.[/b]
Thanks Doc Olds-
That solved the problem= I overfilled it.
Maxine Rennspies
Mar 4, 2020 12:55 PM
ski.dive
Jul 7, 2019 09:20 PM
hmer
Apr 26, 2017 12:08 PM
Kkneat
Feb 7, 2016 03:31 PM
HERHMR
Aug 13, 2007 08:02 PM
