Radiator
Old 09-15-2017, 03:37 PM
Huntrb's Avatar
Default Radiator
Need a radiator for a 2006 H3. Any suggestions? Are the ones at Advance Auto any good. Need one soon and don't want to wait on shipping.
Old 09-17-2017, 04:26 PM
K0PIR's Avatar
I put in a Silla in March and am pretty happy with it. I added an external transmission cooler also. Got both off of Amazon. Pretty easy install.
Old 09-19-2017, 01:40 PM
flahiker49's Avatar
I'm sure the Advance Auto will work, but I'd try to find one that was a little larger, with less plastic, and heavy duty. And I'd install a transmission oil cooler with it.
Old 09-19-2017, 03:13 PM
When something breaks, i fix it..... right the first time, so I do not have to mess with it later. I went with the CSF Racing all aluminum H3 replacement radiator.
Had to modify my PCMofNC Efan to make it happen, but it cools like crazy and it won't get a crack or have any plastic tank cap/base separate from the aluminum cooling fin tank.
Old 09-19-2017, 07:28 PM
Huntrb's Avatar
Thanks for the replys. I opted for a Spectra Premium CU2855 from Amazon. About $145 and 2 day free shipping if you have a Prime account. Fit just like original except it seems to have a bit more clearance between radiator and frame where most of the cracks come from. I do like the looks of that all aluminum one.
Old 09-20-2017, 09:58 AM
flahiker49's Avatar
Yes, this is the exact one I was talking about, I just couldn't remember.
Old 09-20-2017, 06:28 PM
BruceS's Avatar
So far loving my csf. Still working on shroud for efan
Old 09-20-2017, 09:38 PM
happythree's Avatar
im driving with no shroud for abt a yr. see no diff. just gotta be careful to not get my nails trimmed!!
left off after water pump job.
im thinking safety is main reason for it.
Old 09-21-2017, 07:49 AM
AutoRoc's Avatar
I installed a cheap Silva radiator at the 60k mark and now im over 108k.. money well spent, its never failed and I tow 3000lbs a few times a month also. Anything is better than OEM apparently, goodluck!
Old 09-21-2017, 10:31 PM
Kyletentative's Avatar
Default Radiator
huntrb, i bought a wrong radiator online. My h3t is manual and it does not have a transmission cooling lines to the radiator. The one i bought had the transmission cooling lines. Do you know if there just a cover to the transmission cooling lines hole in the radiator?
thanks.
Quick Reply: Radiator
