programming an H3 speedometer reset as preliminary for BCM transplant
Old Nov 24, 2025 | 07:03 AM
SLion's Avatar
Question programming an H3 speedometer reset as preliminary for BCM transplant
If you have suffered water damage to your BCM, you may decide to replace it with a used unit. If you do so, the odometer on the instrument cluster will post an inaccurate mileage and stop working. To resolve this you need to reprogram the 93C56 chip on the cluster control board to zero miles. Along with that, you need to program the BCM eeprom chip to the correct mileage for your vehicle.
Then, when you start the Hummer, the speedo will query the BCM for the mileage and the correct mileage will display on the Speedo odometer, and.. the odometer will start to function again.
After finding no comprehensive resource that illustrates how to do this without expensive equipment I did some digging to find out how and have produced a video that shows how to do it using the CH341A programmer (about $30) and TachoSoft odometer software (about $50). The link is attached. You will need to know how to solder, you should have access to a hot air station for removing the chip, need a computer or laptop with a USB port, and should have some mechanical skill.
Old Nov 24, 2025 | 08:56 AM
Happy Hummer's Avatar
Thank you. Good stuff.
Old Nov 24, 2025 | 10:21 AM
I hope I never need this..... Thanks for sharing.
Old Nov 26, 2025 | 02:34 PM
SLion's Avatar
U r welcome
SLion
Hummer H3T
Sep 27, 2025 08:45 AM
Michele31415
Hummer H3T
21
Aug 16, 2025 01:27 PM
Damkdd
Nov 11, 2019 06:32 AM
TheLion
May 29, 2019 09:50 AM
hyposho
May 27, 2010 03:58 PM
