power steering leak
Old Feb 17, 2014 | 08:34 PM
soonermaniac's Avatar
Default Figured out the pressure pin
I figured out the problem. I put the pressure pin in wrong. It's supposed to go with the pin coming through the coupling. I improved my replacement speed though. Took me 45 minutes to remove the entire pump, pull apart the tank and reassemble and reinstall and test drive. Just sucks it took me 4 hours to figure it all out earlier today.
Old Mar 16, 2020 | 02:08 PM
thumpros's Avatar
Default SteeringRack CAP SEALS necessary..
Greetings HF,
I took notice of the "O"-rings on the H3 steering system diagram.
I'm replacing 190,000 mile Steering Rack on the 2007.Part arrived today complete but without cap seals for the High pressure @ the rack pressure head. Are cap seals or O-rings used on the lines? I have not started the job, just gathering ALL shop stuff prior. Thanks.
Old Mar 16, 2020 | 02:21 PM
Originally Posted by thumpros
Greetings HF,
You dug up a SIX YEAR OLD THREAD to tack a question on the end of it????? Please AVOID digging up OLD Threads from here on out. READ: Old Threads/'Necro-Bumping'
Old Mar 17, 2020 | 08:51 PM
thumpros's Avatar
SO......if a thread contains a topic that covers my issue, I can't post a question about it there. I need to start a new post and hope that it is checked. The answer is still not given and the post contains a submission from a member who obviously has done this repair.
Old Mar 18, 2020 | 08:58 AM
Did you READ my link in blue????? Ask you question in a NEW Thread. Link back to whatever old dinosaur thread if you presume you just have to for people to understand your question.
Do you think the member that did the repair almost 6 -8 years ago is still here, still has their H3?
SafariHummerH2
Jun 9, 2016 12:12 PM
Hooty-Hoo
Oct 13, 2013 11:54 AM
Tram
Jun 29, 2012 12:04 PM
ARonBoard
Feb 1, 2011 10:20 AM
CJ
Oct 17, 2007 11:18 PM
