Persistent P0102 code
Old Dec 9, 2021 | 07:29 PM
bassackwards's Avatar
Default Persistent P0102 code
This code has been plaguing us for a couple of months. We tried almost everything and it keeps coming back.
It is hard to remember but it may have started when a rubber transmission cooler line sprung a leak and fluid sprayed all over everything. We have tried to clean the plug with everything up to brake cleaner to no avail. We had 3 MAF sensors all throw the same code, even went to a junkyard and purchased a few air box and all the parts to ditch the K&N filter and go back to stock.
My last hope is to change the harness plug but I really did not want to cut the original off.
Any ideas?
Old Dec 9, 2021 | 07:57 PM
We do need to check voltages at the plug. Anyone know what the voltages should be?
MAF sensor signal shorted to ground or ground circuit problem.
Old Dec 9, 2021 | 08:09 PM
Can you walk me through troubleshooting? We have a good voltmeter but don't know what we are looking for
Old Dec 10, 2021 | 11:17 AM
Any ideas?
Did you try the obvious? CRC Electronic Cleaner? Spray a chit ton from both sides of the connector, let completely dry, reconnect.
Easy stuff...I would strip the loom covering off the MAF wire harness to the connector and follow it back as far as possible inspecting the wire insulation is all good, no cracks/frays etc.. If you find loss of integrity, you can buy a new MAF pigtail and splice it in with a brand new connector attached.
ulthummer
Oct 11, 2021 11:23 AM
fastNYsix
Aug 31, 2021 06:21 PM
hummer_on_fumes
Jun 21, 2018 01:10 PM
mephis2012
May 4, 2015 10:21 PM
user 956363738
Jan 19, 2012 10:14 AM
