How is it dangerous? :confused: been my go to test for many decades, also works great when I have to pull a towed in parking lot drop, fuel pump failure, into the shop, to repair. :cool: You can also try starting fluid, which may cause damage to the engine, or throttle body cleaner works too. If it starts, then you have a fuel issue, if not, you know there's another problem.
Btw, as state above you can take a prybar on the CK pulley and see if moves. https://cimg0.ibsrv.net/gimg/www.hum...201a908c2c.jpg |
Update... Root of my problem was that the timing belt tensioner broke. The oil on top of the valve cover was a small crack (now fixed). A bag of money later and my engine has been rebuilt. Runs great...
Problem - I still have the infamous stalling when the truck is warmed up and coming to a stop. It does not happen in the first 10 mins when truck is cold. After than, RPMs bounce around and it periodically stalls unless I hold the RPMs wit hthe gas pedal while slowing down to a stop. Any ideas? Ive read a lot here and online re this stalling issue. Ive removed and cleaned TB 2X, MAF 2X, tried changing the EGR valve. What next? Thinking O2 sensors, MAP sensor, fuel filter/pump.... Also booked an appt w dealer to update PCM (fingers crossed). Thanks. |
I changed my Camshaft Position Sensor to a generic amazon one. Today I bought an AC Delco and now the truck seems to idle better but still stalls when the truck is warmed up and harder braking/stopping.
PCM flash Tueday. |
H3s do NOT have any EGR valve. Did you check that all the fasteners for the intake manifold are tight?
This is the list: Acts like it wants to stall/rough idle -No CEL -What To Do: |
Thanks Doc. I have checked and the manifold is tight.
Yesterday, I did a number of hard stops to simulate and diagnose. One time the Word OIL flashed on the dash so I pulled over and checked .... the oil was at the bottom of dipstick. Odd since engine was rebuilt 1200 kms ago. I topped up the oil and has not stalled since. Guess H#s have an auto shutoff for where the oil gets too low. Will continue to monitor. Fingers crossed I don't have a leak somewhere. |
Originally Posted by gwarrend
(Post 379900)
Yesterday, I did a number of hard stops to simulate and diagnose. One time the Word OIL flashed on the dash so I pulled over and checked .... the oil was at the bottom of dipstick. Odd since engine was rebuilt 1200 kms ago. I topped up the oil and has not stalled since. Guess H#s have an auto shutoff for where the oil gets too low. Will continue to monitor. Fingers crossed I don't have a leak somewhere. Was this resolved . I am having the same symptoms and I am now afraid that if I replace the timing chain and tensioners, it might be something else. The truck is throwing errors p0016, p0017, p0365 and p0366. Help! |
Originally Posted by magamaga
(Post 418909)
Help! |
(Post 418909)
Help! We do not need to resurrect this SIX YEAR OLD Dog. READ: Old Threads/'Necro-Bumping' |
| All times are GMT -5. The time now is 09:53 AM. |
