oxygen sensor voltage >0 cold KOEO
Old Oct 18, 2023 | 06:58 PM
Justinh's Avatar
Default oxygen sensor voltage >0 cold KOEO
I have a V6 engine where one of the downstream O2 sensors reads .005v cold and KOEO. During sensor warm up it will be ~.005v higher than the other downstream sensor. After the engine is hot, and the engine is turned off, both sensors will read >0 (something like .007 to .003).
.005v is really low. Does it matter? Is it a sign that the sensor is going bad?
Old Oct 20, 2023 | 12:47 PM
Justinh's Avatar
Default O2 sensors have voltage when cold
Both of my O2 sensors were reading .45V with KOEO (after sitting overnight). Is this typical of narrow-band O2 sensors?
After I started the engine, they seemed to behave normally.
Old Oct 20, 2023 | 01:10 PM
Does this have anything to do with a Hummer? Since none have a V6 I think you are asking questions on the wrong forum site and we can't answer because we do not know what the vehicle is to determine if your voltage is in spec.
Old Oct 21, 2023 | 10:32 AM
Justinh's Avatar
This is about my H3 I5.
Golfing1849
May 9, 2022 11:59 PM
04colyZQ8
May 2, 2011 06:22 PM
SpeedRacer
May 26, 2008 11:51 PM
vilim12
Jan 7, 2008 04:11 PM
