Oxygen sensor - P1133 code
Old Jul 23, 2019 | 12:33 PM
CarlosC's Avatar
Default Oxygen sensor - P1133 code
Looks like one of my oxygen sensors might be going bad... I got the following code:
• P1133: Oxygen Sensor System - Too Few O2S R/L and L/R Switches . (Bank 1 - Sensor 1)
Can you guys tell me exactly where this sensor is located? Hoping its an easy fix.
Old Jul 23, 2019 | 03:01 PM
Hey Carlos....
Pretty easy. An I5 only has one bank (one exhaust manifold because it is a straight head not a V which has one on each side).
There are two positions, sensor #1 and #2. #1 is the front one closest to the head, #2 is farther downstream.
They are numbers 2 and 5 in the diagram. The No. 2 in the diagram is position 1. Might look into an O2 changer socket if you do not have one, it has a slot on one side for the O2 wires to go through. I made mine out of an old spark plug socket years back.
Old Jul 23, 2019 | 03:09 PM
On the exhaust manifold.. Cut the wires, put a deep socket on it to remove.
Old Jul 23, 2019 | 03:33 PM
CarlosC's Avatar
Perfect, thank you both!
Old Jul 29, 2019 | 12:46 PM
CarlosC's Avatar
Just a quick update... replaced the sensor with AC DELCO part #213-3207, took me about 10 minutes. Cleared the code and it hasn't come back. I wish every job on my H3 could be this easy.
1151Gunner
Jan 25, 2018 12:09 PM
jman1335
Oct 20, 2017 09:05 AM
2005H2
Dec 14, 2016 06:07 PM
Trailermedic
Jul 30, 2014 12:59 PM
C31322
Sep 11, 2013 03:27 PM
