Off Roading on 18" wheels??
Old 11-30-2007, 10:46 AM
Desert Dan's Avatar
Default RE: Off Roading on 18" wheels??
Why do you think the Adventure Package has 33's on 16" rims?
More sidewalls give abetter ride and flex at low pressureand moreroom beteween the rim and rocks.
Old 11-30-2007, 11:10 AM
the bigger question is what size tires are you running....18's would be ok for a 37"+ tire...but for a 35" tire17 is the biggest I would go.
Old 11-30-2007, 06:07 PM
Hummer Guy's Avatar
With that wheel you're probably going to have a wider tire - which you can still get an agressive tire, and you're only losing one inch of sidewall. Keep in mind, airing down is to give yourself a wider footprint...by having a wider tire installed, you will lessen the need to air down to get sidewall traction. Now, serious rock climbing when the tire really grabs on, you may see a difference...but the main danger isjust scratching and denting when larger rocks get tossed around -- I wouldn't let it hold you back from buying the wheels, though.
Check out how wide/agressive these tires are on 20s:
Old 11-30-2007, 07:09 PM
RealJeep's Avatar
I can't understand how the Hooptie HUMMER trend has whored out the off road tire market. Off Road Tires need to have side wall thickness, it helps to absorb the shock, gives flex and bight and lessens the work shocks have to do. All those thin side wall tires are good for are making RAP videos and wearing out your A** on bumps because of the lessened rebound rates.
Old 11-30-2007, 08:40 PM
VanSmite's Avatar
Thanks for the input guys. I will be going with 17's at the most so I will keep looking.
Old 12-01-2007, 01:48 AM
skeeet's Avatar
I just would not want the rim to stick out past the sidewall. I have seen too many rims bent up because the side wall of the tire did not extend enough. That is why I really like the 35's with the stock 16' rims but the 33's work good too.[/align]It's either a Hummer or a pimp mobil- make up your mind.[/align]
Old 12-01-2007, 02:46 AM
Feez68's Avatar
I think any wheels over 16 or 17 inches look ghetto on ANY vehicle, whether it's a street car, or a Hummer. Why would you want to copy ghetto fads of criminals?
Old 12-01-2007, 09:51 AM
Hummer Guy's Avatar
So this vehicle has 'ghetto' wheels? (they're 20 inches)
Old 12-01-2007, 10:42 AM
i dont think that every body that have 20'are ghetto or criminals but thats just my two cents but then that just mei only have 16'so what do i no
Old 12-01-2007, 12:15 PM
TheGunnyRet's Avatar
Man! Nothing changes if you keep the same tire Hight as the OEM specs, 33" is 33" whether you have 2" sid walls or 6" side walls. Your Tranny PCM is programed to what tire came originally with the Hummer you bought you "Maggots" Here is some edumacation tools.
http://www.dakota-truck.net/TIRECALC/tirecalc.html, http://www.wheelsmaster.com/rt_specs...0RAM&text2=, http://www.offroaders.com/info/tech-...ng/mph-rpm.htm
P.S. My intention is not to offend.
Quick Reply: Off Roading on 18" wheels??
