O2 sensor recommendation
Old Nov 22, 2021 | 09:52 AM
Mike2008's Avatar
Default O2 sensor recommendation
Anyone have a recommendation of which brand of O2 sensor should I get to replace my current ones?
Old Nov 22, 2021 | 11:25 AM
Old Nov 22, 2021 | 12:52 PM
Why are you replacing any? Sport? Boredom? Nothin better to do? Ugly girlfriend?
Obvious correct answer = ACDelco.
Old Nov 22, 2021 | 01:53 PM
That's right, get the denso in the blue box, at a higher cost, if it makes you sleep better at night.
Old Nov 23, 2021 | 11:01 AM
Mike2008's Avatar
Got the p2270 code plus hearing a rattling sound in the exhaust pipe under the drivers seat location and it’s near the sensor there.
Old Nov 23, 2021 | 11:07 AM
Easy stuff first. Change the sensor and while you are there, inspect the wire harness to it, connecter should be sprayed with electronic cleaner before plugging in the new one, and look at the heat shield for a rattle.
Could be a bigger or different problem, but rule out the sensor first.
Old Nov 23, 2021 | 11:29 AM
Check for an exhaust leak using soapy water and low pressure air into the tailpipe to find the leak. For an exhaust leak the hose into the tailpipe with air, sealed with shop towels, then soapy water would be sprayed around seals, seems, and bosses.
Old Nov 23, 2021 | 11:58 AM
if your hearing rattling noises the catalytic converter is probably breaking apart internally and the sensors are probably fine. if you can get an inspection camera through the first oxygen sensor hole you might be able to see if the cat is damaged. they do sell oxygen sensor spacers for the rear o2 sensors that will trick the ECU into compliance but it will do nothing for a clogged catalytic.
Old Nov 23, 2021 | 02:32 PM
Forgot to mention... whenever you ask a question, YEAR, MODEL, MILES and a description of any recent work done just before the onset of symptoms should always be included.
Old Nov 23, 2021 | 02:47 PM
I got the YEAR, MODEL via the excellent search feature here on HF. I agree it's important to include as much information for proper assistance!
New member. I been an owner of a 08 H3 Alpha for a few years. Love the truck and it's been pretty good. I do think the previous owners neglected maintenance on it but, now I'm getting around to it. Posts I've read have been helpful so will continue to be frequent the forums.
