Nuclear EMF effect on electronics?
Old May 14, 2025 | 07:01 AM
wpage's Avatar
Question Nuclear EMF effect on electronics?
Someone asked if my 06 H3 would still run if there were a atomic blast with a Electro Motive Force type influence?
I had no clue. So in a doomsday blast any data on if we run or get stuck in the disaster?
Gurus please answer...
Thanks for looking.
Old May 14, 2025 | 08:41 AM
I stopped and asked Elvis this morning. He was on the shoulder of Westbound I94 changing a flat on his Caddy on the way into Detroit. He had Jesus Christ in the passenger seat. They both said BS. So we are good.
Old May 14, 2025 | 09:36 AM
unless your H3 is carburated with points ignition and uses vaccume tubes for its electronics or your garage is a lead vault. then you will be affected like the rest of humanity. well unless they keep there vaccume tube powered, carburated, point ignition h3 in a lead faraday vault for such an occation. the bat cave might even due if wayne is not using it that weekend.
Old May 14, 2025 | 09:38 AM
it is your vehichles wire loom that absorbs the EMP like a wifi router picks up wifi.
Old May 14, 2025 | 09:45 AM
What if we wrap the vehicle in two layers of HD Tin Foil?
Old May 14, 2025 | 02:33 PM
@Doc Olds Dude, you know that each of the 2 layers need to be wrapped 180 degrees from each other and the tires need the same treatment for it all to work
Old May 14, 2025 | 02:36 PM
Looks like the roof rack is exposed which will "foil" the entire effort.
Old May 14, 2025 | 05:46 PM
Thanks for looking.
No HUMMER, however the HMMWV will still run.
Top 10 EMP Proof Vehicles for Your Emergency Preparedness Plan
Old May 14, 2025 | 06:06 PM
Old May 14, 2025 | 06:51 PM
Happy Hummer's Avatar
The heat from the blast and fall out would undoubtedly leave a lasting effect. Think Hiroshima times many. SHADOWS.
