Is this a normal start?
Old Jun 12, 2023 | 04:17 PM
Eurynomestolas's Avatar
Default Is this a normal start?
2007 i5 h3 startup youtube video
Old Jun 13, 2023 | 07:07 AM
smtichy's Avatar
Hi Eury...
The sound in the video is pretty faint, hard to diagnose, do I hear the motor pulsing? More details would help.
With that said my 2007 i5 sometimes sounds rough on startup, there were a dozen things to go through to quiet it down.
... clean the MAF, throttle body, change plugs, replace cracked PVC hose, new belt tensioner, tighten a loose heatshield, etc.
the devil is in the details and each has a few specific sounds and signs to give a hint what may be the cause. Codes help too.
And while after doing all the above it runs better, but somedays is still noisy on startup
Old Jun 13, 2023 | 08:35 AM
Originally Posted by smtichy
Hi Eury...
yes sounds like a pulse. I just wanted to compare. when you start your h3 up does rpm do the same thing? I have no check engine lights and have taken care of the above. actually just replaced the maf with acdelco just to make sure. something weird is going on on start up
Old Jun 13, 2023 | 04:53 PM
Justinh's Avatar
My 2010 does not sound like that.
Old Jun 13, 2023 | 05:42 PM
ENGINE SURGE, NOT NORMAL, Air / Fuel Management issue!
Easy DIY to correct, first start by disconnecting CAI @ TB and recheck.
Old Jun 13, 2023 | 06:15 PM
could it be a bad throttle body?
Old Jun 13, 2023 | 06:17 PM
? start by removing CAI to TB and recheck. Any difference?
Old Jun 14, 2023 | 05:49 AM
smtichy's Avatar
No my RPM is steady, it may idle a little rough, but no fluctuations. If cold of course it idles faster and gradually slows down.
Check all your sensors, connections, etc.
Old Jun 14, 2023 | 06:19 AM
will have to check at a later date. She wont start now. guessing starter 😵‍💫 alternator was just replaced battery has charge. Ihear ticking but not cranking.
Old Jun 17, 2023 | 01:34 PM
i checked this and still no change it is only on the start for the first day or if it sits for awhile.
