No compression on cylinder #3
Old Jul 28, 2022 | 12:19 PM
  #21
Hummer6895's Avatar
Originally Posted by register1987
Ok I used a left handed drill bit and it pulled the broke bolt right out. I had the head rebuilt at a local shop for $240. I am getting ready to install the head tonight. While reading thru the install steps it says things like.
Tighten the cylinder head bolts in sequence to 22 ft. lbs. (30 Nm). Use the J 45059 to rotate the cylinder head bolts in sequence an additional 155 degrees.
Do I just turn the bolt 155 degrees after I reach the required torque.
would you say 600 for a remanufactured head with all new valves, springs, lifters/lashers, cams ect installed so it's just a fully built head pull and install worth it?
Old Jul 28, 2022 | 02:51 PM
  #22
Who are you talking to in this SIX YEAR OLD THREAD? Register 1987's Last Activity: 08-20-2021 12:32 PM.
Not how it is done. Start a NEW THREAD, avoid digging up OLD Dawgs. READ: Old Threads/'Necro-Bumping'
mommasbaby
Dec 14, 2013 07:02 AM
mthoodh3
Feb 15, 2012 10:16 PM
alexismya
16
Dec 24, 2011 11:22 PM
bladehummer
Aug 31, 2010 12:46 PM
beachman
20
Dec 14, 2006 01:08 PM
