Need help my h3 is acting up!
Old May 19, 2014 | 10:43 AM
omarluna2's Avatar
Default Need help my h3 is acting up!
Hello everyone, I am having trouble with my 2006 Hummer H3. The H3 idles rough really bad and it sometimes turns off when I get to a red light or a stop sign. I took it to the local GM dealer but they were not able to fix the Hummer. It drives awesome on the freeway but if im in the city it tends to turn off about 1/5 of the time when I come up on a stop. The check engine light comes on and off. But, I was able to get these four codes of the machine. C0240 Powertrain Control Module traction Control Not Allowed. C0268 Class 2 Data Error Reported History. P0017 Timing Misalignment Explanation, Detected the Crank Sensor is not Aligned with Cam Sensor, Probable cause intermittent connection, Failed Crank or Cam Sensor, Engine Mechanical Condition. P0300, Cylinder misfire detected- random cylinders explanation, The powertrain control module monitors the crankshat speed and had detected a misfire condition, proable cause ignition system faul-spark plugs, ignition wires, coil, vacuum leak, injector fault, or low fuel pressure. I had the hummer at the dealer for about 18 days. Im not even sure they did anything to the Hummer honestly, I looked at the spark plugs and they were considereably shorter than i expected. Went and got the original ones and also, put a new filter on it. but, its still acting up. The dealer said it put new sensors on it, but i dont think they did. at this point i would rather do it myself. Can anyone help me?
Old May 19, 2014 | 02:30 PM
RKSmith163's Avatar
Search: Battery Terminals/Battery first then Throttle Body Cleaning and MAF Cleaning. Multiple codes can be caused by bad battery terminals or a failing battery. Good Luck
Old May 19, 2014 | 04:04 PM
Replace camshaft position actuator solenoid
More info here:
https://www.hummerforums.com/forum/h...missing-32913/
Old May 19, 2014 | 05:08 PM
omarluna2's Avatar
Default Awesome
So the camshaft position actuator solenoid is the problem? Does this cause the Idle? Just wondering.
Old May 19, 2014 | 05:18 PM
That is correct.
Old May 19, 2014 | 05:44 PM
X2 on the cam position sensor. If that does not fix it you may have a stretched timing chain.
How many miles on it?
Old May 19, 2014 | 08:43 PM
omarluna2's Avatar
It has nearly 149000 miles. Would the Timing chain cost a lot to fix?
Old May 19, 2014 | 08:55 PM
skeeter's Avatar
yes, unless you do it yourself and it will cost alot of time.
Old May 19, 2014 | 10:46 PM
omarluna2's Avatar
Im going to do all of these keep you guys updated. Ill be free this upcoming weekend. im already ordering the parts. Hopefully its one of these things.
Old May 20, 2014 | 04:30 PM
There's only 1 camshaft position actuator solenoid. Around 40bucks, 10minutes, 1 socket, and 1 beer, to replace.
