Need help with identifying this part...
Old May 9, 2020 | 08:42 PM
Donald Austin's Avatar
Default Need help with identifying this part...
I have a 2006 H3 Its a silver finned something that looks like the right side is injured, from heat maybe?
Was wondering if this part could affect engine performance
Old May 9, 2020 | 09:00 PM
coil pack?
Old May 9, 2020 | 09:20 PM
I guess you could call it a "failure", but I prefer the term "learning experience".
Old May 10, 2020 | 09:10 AM
Happy Hummer's Avatar
Let me know if you need one. I've got one you can have. Works.
Old May 10, 2020 | 11:53 AM
Do you know if this could affect idle/ power occasionally erratic?
Old May 11, 2020 | 09:17 AM
It is a coil on plug pack, and has to fire the spark plug fully and consistently every time the engine rotates a revolution.
So yes they can make idle rough and cause a miss which results in a loss of power and fuel economy.
Old May 11, 2020 | 01:07 PM
LatvjuAvs's Avatar
Reading all the experiences here, almost anything can cause rough idle, also rough idle is like Hummer H3 hallmark.
If you will use search on this forum, you will have reading material for days of all possible reasons.
What does "looks like the right side is injured" means? That rusted spot there on epoxy?
Old May 16, 2020 | 11:02 AM
yeah, but also indents like from heat, i guess these coil packs heat up quite a bit?
Old May 16, 2020 | 11:04 AM
thanks happy hummer, im not sure thats my problem, i fooled around ith the connectors going to coil pack and other connectors, and now seems to run fine except for a minor rough idle
Old May 16, 2020 | 10:03 PM
Originally Posted by Donald Austin
minor rough idle
All it takes is research on this site. Mine still idles smooth as glass.
Wayne Auto Ebay
Jun 15, 2020 11:01 AM
MJ Bunker
Sep 11, 2018 06:35 AM
sstevenson1007
Feb 7, 2016 03:13 AM
kd4ave
Dec 28, 2013 11:41 AM
