Need heat switch for a 2007 H3
Old Sep 1, 2021 | 02:33 AM
Luckelinda's Avatar
Default Need heat switch for a 2007 H3
I am looking for a heat switch for my drivers side seat. When driving my switch turns itself on and my seat starts to heat up. The push switch goes to the high position and then I need to push it to neutral middle position. I don’t know if it the movement when I sit in the seat that causes it turn on or what. Any suggestions where I might find one or replace it. Could not get one through repair shop. They don’t make part anymore.
Old Sep 1, 2021 | 10:16 AM
All H3 questions go in the ......................................... yep..................... H3 section.
There is nothing wrong with your switch, your seat trim panel is broken so when you climb in or out it moves and in turn moves the switch. You can replace the trim piece, or learn how to get in/out without sliding over the side, and/or check it with your hand after you get in. My 09 Alpha was owned by prior fat azzed people who broke both sides because they were to lazy to enter or exit by getting up instead of sliding over.
Old Sep 1, 2021 | 01:11 PM
Luckelinda's Avatar
Default Seat trim panel
Thank you for replying to my problem. Where is it possible to get one online? I am a senior (68 yrs) and as you said a little fat azzed and so are my senior friends. I had a hip problem and was having a hard time getting in and out. Hip replaced and easier to get in now. Love my Hummer and won’t part with it as long as I can get in it. I will look for a seat trim panel. Will it be hard to install? Big job? Thank you again for your fast reply.
Old Sep 1, 2021 | 03:21 PM
We have established we are both seniors and we are both on the internet. The internet is where you will find your seat trim part with a Google for "H3 Hummer seat trim". You have to pick color, so I am not going to find one for you and I am not going to install it either. It is a simple install, couple screws and clips, call one of your kids and have them figure it out if you can't.
Good luck
Old Sep 1, 2021 | 09:40 PM
Luckelinda's Avatar
Thumbs up Thank you
Thank you again for quick reply. Sorry to have given too much info before. Found what was needed.
Old Sep 2, 2021 | 05:01 PM
Broken Halo's Avatar
As Doc said the trim panel can trip the switch by flexing when you move around in the seat....poor design. People have fixed this by adding a screw thru the panel into the support behind it to keep it from shifting. This picture will show you the location for the screw that has been used as a fix.
Old Sep 2, 2021 | 05:44 PM
650Hawk's Avatar
/\ This
Old Sep 2, 2021 | 08:43 PM
Luckelinda's Avatar
Smile Thank you
Thank you for suggestion. I’ll have someone do this for me.
Joegrillo
Jan 20, 2021 04:48 PM
Naji Moh Nasir
Mar 25, 2020 07:37 AM
egroegart
Aug 27, 2012 11:59 AM
drbombay
Sep 3, 2007 07:07 AM
