Originally Posted by wfturner
(Post 320182)
Here is where I bought the bulbs used in the window switches.
yes, they are easily replaced. Pry up the switch housing, carefully !!!! Then unscrew the base of the switch module and you will see the bulb bases. Unscrew old ones and replace and reassemble These bulbs come with the twist in base and the bulb condom for the correct color. Buy more, because others will burn out over time. http://www.ebay.com/itm/Hummer-H3-20...130cf1&vxp=mtr Here is a better price and just reuse the blue condom from the old bulb http://www.ebay.com/itm/251327067799...%3AMEBIDX%3AIT I found the link you indicated is not working anymore... may you have another solution? need to buy bulbs for windows paddle doors control... THANKS! ))) |
Originally Posted by ik5mdf
(Post 392276)
HI!
I found the link you indicated is not working anymore... may you have another solution? need to buy bulbs for windows paddle doors control... THANKS! ))) You are on the internet........... GOOGLE it. READ Old Threads, do NOT resurrect them. |
