MAP SENSOR location
Old Oct 25, 2014 | 02:28 AM
juicebox123's Avatar
Default MAP SENSOR location
Or a how to change it would be nice...
Pictures would be helpful because I'm trying to do this myself.
YES I have looked around and put in the search engine Manifold Absolute Pressure sensor and MAP sensor and I'm not getting much in results.
I heard it's near the throttle body... but ya I have no idea what that is.
Before you tell me to not touch my H3... I want to try to fix it myself, you can't learn if you don't try. I also heard this was relatively easy to fix.
Or if anyone has pictures of the actual part in the actual engine because I have tried looking at
http://schwarttzy.com/wp-content/upl...nical-3.5L.pdf
AND cannot figure those pictures out.
THANKS!
Old Oct 25, 2014 | 04:57 AM
Manifold Absolute Pressure sensor located on the intake manifold.
intake manifold on drivers side of engine:
Map sensor is on top of intake manifold (#1)
Old Oct 25, 2014 | 08:37 AM
See that's the same picture I already saw that doesn't make too much sense. :/
So I'll need tools? Any idea which?
The first picture looks like it's saying take this apart but if it's on top why do I need to? Its not under the part that gets removed.
Old Oct 25, 2014 | 11:43 AM
unplug the connecter, then push the 2 V-tabs inward and pull the sensor upward.
Old Oct 25, 2014 | 12:09 PM
Happy Hummer's Avatar
Good luck. You can do it. Just take your time and if in doubt re look at it again b4 doing something.
Chris
Old Oct 25, 2014 | 02:22 PM
So from the first pic... I don't need to remove that part? That's what is confusing me.
I just remove the black cover and it's under there? That's it?
Old Oct 25, 2014 | 03:45 PM
It's best to have the replacement part in hand then you would know.
No, you do NOT have to remove the manifold.
Old Oct 25, 2014 | 06:28 PM
Having the part and looking at it. Got it. .. just these v tabs are freaking stubborn. ..
Old Oct 25, 2014 | 08:08 PM
I did it! Thank you
darrenz
Oct 7, 2013 08:52 PM
rolnsolo
Jun 16, 2012 07:59 PM
31sonic
Feb 8, 2012 10:16 PM
bheff
Jun 24, 2011 08:41 PM
alex2mil
16
May 21, 2008 06:40 PM
