Luis21
Old Apr 9, 2015 | 05:54 PM
Luis21's Avatar
Default Luis21
Hello, my name is javier. The rack on pinion on my 2006 hummer h3 is leaking oil. I need to replace it, but I am not sure what size it is. Anyone know how I can find out the size so I can order the part. I have called the dearler to figure if It is 14mm or 16mm but they cant give me an answer.
I have the name, number part number if helps to figure the size.
Part NAME:. Gear ASM STRG
PART No. 15827235
Serial No. AKLSS 085
Thks friends
Old Apr 10, 2015 | 08:41 AM
Welcome. I MOVED your tech question from the new member area to the H3 section where you will get some help.
Might want to look at this while you are at it. Steering Rack Reinforcement Kit - OUTFITTER DESIGN
Old Apr 10, 2015 | 09:10 PM
skeeter's Avatar
the rack is the same size. the tie rods are different sizes
