Longer horn chirp?
Old Feb 27, 2020 | 12:25 AM
GrampaEJ's Avatar
Question Longer horn chirp?
Didn't mean to start a pissing match. Post Deleted.
Last edited by GrampaEJ; Feb 28, 2020 at 08:17 AM. Reason: Didn't mean to start a pissing match. Post Deleted.
Old Feb 27, 2020 | 05:57 AM
May I ask WHY you want the audible signal that your vehicle is locked to be loud and long?
Old Feb 27, 2020 | 08:52 AM
Alpha X's Avatar
People that need the horn to honk confirmation while locking the car have an anxiety disorder. Furthermore, if you were my neighbor and made your locking horn sound longer, you'd be replacing your windshield often.
Old Feb 28, 2020 | 11:03 PM
Brayden D.'s Avatar
Yalls chirps? I wish mine did, every morning in class I cant remember if I locked my truck and worry about it all day.
"People that need the horn to honk confirmation while locking the car have an anxiety disorder." - Yes, we do.
Old Feb 29, 2020 | 08:22 AM
Parking lamps flash is all I need to confirm.
If you need to change:
Remote Keyless Entry (RKE) Feedback
This feature allows you to program the Remote
Keyless Entry (RKE) feedback to a preferred setting.
To set your choice for this feature:
1. With the engine off, turn the key to LOCK/OFF.
Do not remove the key from the ignition.
2. Press and hold the lock and unlock buttons on the
RKE transmitter at the same time. Hold both
buttons until the DIC display shows the current RKE
feedback mode
3. To view the next available mode, press and hold
the reset stem until the mode appears. Release
the reset stem and press and hold again to view the
next mode.
4. Once the desired mode is shown on the DIC
display, briefly press the reset stem to set your
choice. The DIC display then clears.
The following are the available modes:
RFA 1 (default): This mode flashes the parking lamps
when you press the lock or unlock buttons on the
RKE transmitter.
RFA 2: This mode flashes the parking lamps and
sounds the horn when you press the lock button on the
RKE transmitter. This mode also flashes the parking
lamps when you press the unlock button on the
RKE transmitter.
RFA 3: This mode flashes the parking lamps and
sounds the horn when you press the lock or unlock
buttons on the RKE transmitter.
RFA 4: This mode disables RKE feedback. There will
be no feedback when you press the lock or unlock
Old Apr 3, 2021 | 04:00 PM
Nonibot's Avatar
feedback mode
next mode.
RKE transmitter.
RKE transmitter.
Thank bruv, but I already mentioned in my original post that I've done this and set it to RFA2 as well as RFA3 but either times the response has just been the flashing parking lamps as always. It was originally set to RFA1.
No horn chirp still :/
Old Apr 3, 2021 | 04:02 PM
Nonibot's Avatar
oops this popped up when I refreshed. My bad, replied on the wrong post
dbruno94
Nov 1, 2013 09:17 PM
dbruno94
Oct 28, 2013 11:34 AM
finall
Mar 13, 2010 06:11 AM
Ghostrider
Sep 10, 2008 11:40 PM
Hummergirl4
May 5, 2007 02:42 AM
