Knocking/Thumping (not motor) when throttling up the road
Old May 14, 2018 | 03:21 PM
John Gibson's Avatar
Default Knocking/Thumping (not motor) when throttling up the road
I have a knocking (more of a thumping) that just started. When on the throttle I hear a thumping that speeds as speed increases but stops when I let off the throttle (even if I'm still rolling). Does not thump as I rev the engine, just as I am throttling up and down the road. It is coming from up front. Any ideas before I start breaking it down?
Almost like the driveshaft is hitting something as it turns.
Old May 14, 2018 | 09:55 PM
norinco3264's Avatar
Check to see if the heat shield under the hummer is smacking the drive shaft, just to rule that out.
Old May 15, 2018 | 10:21 AM
Happy Hummer's Avatar
Check your drive shaft, axle shafts, center diff mounts.
Old May 15, 2018 | 01:21 PM
front prop shaft (drive shaft) CV joint at the rear of the shaft.
Check to see if the boot is torn or any grease around the area.
Old Feb 1, 2022 | 10:30 AM
Jscottturner44's Avatar
Default Solution?
Did you ever figure out was causing the problem?
Old Feb 1, 2022 | 12:43 PM
No....... he had the same number of posts as you did, 1. We do NOT dig up old Threads here. READ: Old Threads/'Necro-Bumping'
Ask your own new question in a New Thread.
First suggestion is to get under your truck and LOOK!
05blackduramax
17
Apr 6, 2015 09:19 AM
acepanz
Mar 2, 2012 08:20 PM
Fever4Speed
Apr 12, 2010 08:40 PM
rgvanover
Dec 29, 2009 06:03 PM
hsbertiii
Mar 20, 2007 07:05 PM
