Knock Knock in rain
Old Mar 3, 2020 | 05:31 PM
BamaH3's Avatar
Default Knock Knock in rain
2007 H3 Auto,130k
In the rain and rain only..i pick up a tick, tap, knock whatever noise you want to call it from what sounds like backside of the dash on drivers side. No water on floor. 1st time I heard it, I thought speedometer cable about to break(no cable)..and if you ever had a vehicle with one, you know what I mean. Radio up some,cannot hear it. No Rain.No noise. I am sure it is water,my question is anyone else has encountered this strange noise?
Old Mar 3, 2020 | 05:46 PM
Does the noise stop, when you move the wiper switch, to the off position?
Old Mar 3, 2020 | 06:05 PM
BamaH3's Avatar
NO..i hear it with wipers off
Old Mar 3, 2020 | 07:00 PM
Did you look under the cowl for a critter?
Post a video of the sound. Upload to YT and post url.
Old Mar 4, 2020 | 07:56 AM
If you hear it while moving it is the rubber seals on both A pillar covers.
Some have used 3M double sided tape. Removed the A pillar covers and put a thin band of double sided tape on the rubber seals then reattached to the A pillar and window.
Old Mar 4, 2020 | 11:44 AM
BamaH3's Avatar
Only hear this when it rains. light rain,not so much but a steady rain I will hear it. Takes awhile before the noise starts so I guess the water has to build up in some way.
And no critters that only wake up during riding in the hard rain.lol
Old Mar 4, 2020 | 12:35 PM
do all of your heating/cooling modes work like defrost? maybe an actuator trying to adjust a stuck vent.
Old Mar 4, 2020 | 12:45 PM
Happy Hummer's Avatar
Possibly water dripping through drain hoses or firewall grommet? Or just the sound when it is raining of the water running through those hoses? I know that on our old 06 H3 the drain tube was not fully seated and some dripping did occur but just enough to make a spot of rust on the bare metal under the driver side dash near firewall.
Old Mar 4, 2020 | 12:54 PM
To proceed Happy Hummers input.... do you have a sunroof? Do you have the over cab running lights?
And yes, sun warped aged A Pillars make the noise you are describing to a T.
Old Mar 4, 2020 | 04:30 PM
BamaH3's Avatar
Thanks guys...I will look into the a pillar covers. they are warped and need some attention. This may be where I am getting the water sounds
