key fob replacement
My Ignition key doesn't open my door, and that's the only key i received when i bought it used. I did get two key fobs though. I thought the door lock might be dirty and jammed but it just feels like it's the wrong key. The replacement key fobs are not expensive but i am not sure how much it is to get it programmed.
You'll see cheaper ones, but they are JUST THE SHELL with no guts (don't be fooled)
You'll need to take it to your dealer to get it programmed also.
Yup, saw $10 ones on Ebay. Just called the dealer. $44 to program it. Out the door it'll be $54.
Not sure if it will work but what the heck look at this link. www.ehow.com/how_6559018_program-gm-key-fobs.htm
I picked up a 2 in one key and FOB last month and I really like it. Dealer cut it and linked to to my T for $25 so all in all about $85 for everything.
HUMMER H3 SWITCHBLADE CHIP KEYLESS ENTRY TRANSPONDER KEY TRANSMITTER REMOTE FOB | eBay
It feels good and tight but when the key is flipped in it's a little lose but beside that I love it.
2006, case, chip, entry, fob, h3, hummer, ignition, key, keyfob, keyless, keys, lost, program, relpacement, replacement, switchblade, transponder
