Just Bought A 2008 Hummer h3 Blown Motor
Old Apr 16, 2023 | 07:33 PM
jws123's Avatar
Default Just Bought A 2008 Hummer h3 Blown Motor
First off hi am new to the forums I am a mechanic but usually only work on Crhyslers, Ram Jeep ect I have built a few motors before but I know 100% nothing about hummers never even sat in one until today ahah what common Issues do these have? any preventive maintenance while I have it torn down?
I have a 2008 hummer H3 160k with the 3.7 5 cylinder the truck is really clean frame is solid ect. The trans is suppose to be a year old the current engine has a rod threw the block the owner gave me another 3.7 he was going to install but says he found out it had a spun bearing. I have yet to look into that ye If the motor is not fixable and I wind up needing another motor what motors will interchange?. I see some chevy colorados have this motor and someon told me a ISUZU or something?I usually try to buy wrecks when I need a motor ect so would be nice to know what other vehicles have this motor.
Old Apr 16, 2023 | 07:57 PM
Disel's Avatar
Hello. Hummer has 2 types of engine 3.7. 2007 and after 2007 Don't mix it up. You can determine by the presence of the exhaust camshaft sensor. The engine is simple but suffers from overheating of the 5th cylinder due to poor cooling. The thermostat is at the bottom. Eats up a little oil, but is not demanding on fuel quality (has a VVTI)
Old Apr 17, 2023 | 01:06 PM
jws123's Avatar
Ok thanks so I have to look for a 2008+ engine then
Old Apr 17, 2023 | 02:14 PM
There is NO overheating problem within the block, the guy is in the ozone???????? Look for a 2008 or newer 3.7L out of a Hummer, Chevy/GMC or Isuzu.
Old Apr 17, 2023 | 05:20 PM
jws123's Avatar
So the second motor does indeed have 1 spun rod going to try to contact a machine shop see if they can fix it if not anyone know where to get a crank or bearings? appears no one has anything in stock except 1 place that thinks the crank is worth $1000 Lol.
Old Apr 17, 2023 | 06:06 PM
RVR's Avatar
RVR
Got my bearings @ rockauto.com
Old Apr 18, 2023 | 09:15 AM
jws123's Avatar
Yea I usually use rockauto alot of their stuff is out of stock right now. Question tho if i found a used non damaged crankshaft from a older 3.7 are they the same?
Old Apr 18, 2023 | 02:46 PM
ski.dive's Avatar
Old Apr 18, 2023 | 10:33 PM
jws123's Avatar
Not rly looking for a brand new rebuilt motor as they cost more then the trucks worth I found possibly a used one also dropped the crank off at a machine shop to determine if its fixable I dont think it will be tho grooves where very deep.
Old Apr 18, 2023 | 10:35 PM
jws123's Avatar
Never thought It would be such a pain in the a## to find a crankshaft kit they use to be like $450 I have noticed that for some other vehicles lately guess things are just not being made..
