Jet Performance Module
Old May 18, 2010 | 05:36 AM
Broken Halo's Avatar
I like the idea of the Jet Module as well. I don't want to have the dealership reflash my PCM to reset a trouble light, and then be out the $200 for the PCM For Less. My problem is, I don't know if I should go with the Stage 1 or Stage 2? I DO have the Magnaflow Cat-Backs, Air Doc, and K&N, but if I understand correctly, you also need a 180 degree thermostat, and must burn 91 octane fuel for the Stage 2. Any thoughts?
Old May 18, 2010 | 05:53 AM
marksteven's Avatar
The model number is 20805. It's for the Colorado/h3. Iwent with stage1. Mine is stock.
Old May 19, 2010 | 12:06 AM
DirtyH3's Avatar
I happen to be selling my Jet Module. It's for a 2006 H3 with the 3.5L. $170 shipped. Model number 20305. It works with the 3.5L only. The 3.7L takes model number 20805.
Old May 19, 2010 | 05:59 AM
Didn't it work for you? Did you find something better?
Old May 19, 2010 | 11:23 PM
DirtyH3's Avatar
It worked fine, but I just bought bigger tires and wanted the speedo fixed so I went with pcmforless.
Old May 20, 2010 | 10:51 AM
85_305's Avatar
Banned
Any other input on the Jet modules? i'm really consider doing one in the next few weeks and wanna know more
Old May 20, 2010 | 12:29 PM
marksteven's Avatar
Let's just say my h3 woke up from the dead with the jet module! However I am running 89 octane which is rec. By jet.
Old May 20, 2010 | 01:25 PM
I was ready to pull the trigger on a Jet for my Alpha, so I contacted them directly and spoke to a tech. He said I could expect about 15hp. and 17ft.lbs. torque more. When I asked about increased mpg. he said not going to happen. I said that it seemed to me that, increasing the efficiency of the engine should equate into better mileage. He responded that, the way they get the increase in hp and torque, is to advance the timing, and increase the injector pulse duration. Bottom line: more fuel is used and mpg go DOWN!
Oh well....back to PCM for less.
Old May 20, 2010 | 01:39 PM
marksteven's Avatar
If I had an alpha, I wouldn't do a jet or a PCM. I would go with a hand held programmer such as superchips. As far as gas milage, I've only had the jet for 3 days. If it's worse then it's because I'm taking advantage of the added power and acceleration.
Old May 20, 2010 | 07:18 PM
2wheelmonster's Avatar
great thread, gave me alot to think about, thanks
