It's 2020, how is your H3 holding up?
Old Apr 14, 2020 | 02:13 PM
  #21
650Hawk's Avatar
2008 Alpha/Off-Road here, purchased with 90K about 3 years ago, now have 145K. Added LED light bars on the roof and the grille, LED interior and backup lights, Torsion adjustment, AirDoc style intake. No repairs needed other than HVAC door control module, and a new (OEM) radiator (just about 2 weeks ago).
Old Apr 14, 2020 | 09:46 PM
  #22
wpage's Avatar
Bought a 2006 new. Has 3.5 I5 engine. with 100k miles. No real issues. A spark plug coil. Couple of o2 sensors. One tie rod.
Extremely Satisfied with my H3.
Old Apr 15, 2020 | 04:02 PM
  #23
BlueH3's Avatar
2009 Luxury H3 - holding up well! 92K
Front right drive seal starting leaking about 50K
Stupid column lockout battled for 3 years on and off recently had dealer change it out while in for throttle body replace (too cold out to do!) which due to went into limp mode only when 25F or lower. Runs and gets great mileage now. I cleaned the MAF also.
Replaced driver broken window switch about 70K.
Recently had all the driveline fluids changed with synthetic. Shifts awesome smooth! Front brakes couple weeks ago second set Raybestos ceramic and brake fluid change.
Belt and tensioner and idler changed recently. Check your pulleys! Mine spun like roller blades!! The idler is absolute stupid location to change!! Remove wheel liner, bottom hose, AC line etc...
Other than this just a super cool ride!!
Old Apr 16, 2020 | 03:45 PM
  #24
stwip2006's Avatar
Thumbs down Old Yeller
221,000 + miles and still going strong. So far: replaced radiator, brakes X 2, Radio, clutch and throwout bearing, thermostat, tires X 4, coils X 6, plugs X 3, wheels X 1, windshield washer hoses X 1. Largest complaint: check engine light has been on more than off since purchased new, codes 0327,0327 knock sensor which has been replaced 3 times and the dealer cannot figure out why. I run it on 89 octane and AC deco plugs, second complaint dealers are expensive as hell and aren't worth a pile of crap.
Old Apr 17, 2020 | 07:02 PM
  #25
gsumann's Avatar
I bought a 2007 I5 with 200k and it looks like the previous owner replaced the transmission & Transfer case. Carfax shows the sunroof was serviced 3 times and then finally replaced.
everything works like it should and it looks incredible for a 2007 I commute with it everyday Monday-Friday 75 miles round trip my plan is to keep it 2 years and move on to the next.
Old Apr 17, 2020 | 09:56 PM
  #26
Old Apr 21, 2020 | 09:52 AM
  #27
wpage's Avatar
2006 H3 Slate Blue 100K Outstanding Truck
Old Apr 21, 2020 | 10:36 AM
  #28
What is the 89 octane for? A stock H3 cannot take advantage of that as the factory PCM tune is for 87.
The dealership is the LAST place to take any out of warranty vehicle to for service.
If you want help on the P0327, post up a new thread and we can help.
Old Apr 21, 2020 | 05:37 PM
  #29
wpage's Avatar
Are you asking a question boy...
Old Apr 21, 2020 | 08:45 PM
  #30
Just saying!
