Inside Lights stay ON!
Old May 20, 2020 | 11:56 AM
Alex DjFlaco's Avatar
Default Inside Lights stay ON!
Hello everyone, I really need you guys help with fixing the light issue I'm having inside the door. My inside center light and my inside trunk light stay on and wont come off. My battery already drain once because of this. At this point I just want to at least have it off until I have time to go get it fixed. I have a 2007 hummer h3 (sunroof). I found the fuse box in the engine bay just don't know which fuse it is to for me to remove it so it don't drain my battery. I'm also not sure if theres a fuse box inside the car. Please help so I can remove the fuse so it don't drain my battery. Thank you.
Old May 20, 2020 | 12:32 PM
Chuck234's Avatar
Default Fix
I had the same issue. I went online and purchased new door switches for all 4 doors and the rear. They are the same part number. Takes 10 to install all of them. Problem solved. Cost was about $4 each
Old May 20, 2020 | 12:49 PM
Any idea where you purchase it from?
Old May 20, 2020 | 12:50 PM
Chuck234's Avatar
Gmparts.com
Old May 20, 2020 | 12:56 PM
Ebay or any online auto parts supplier like RockAuto.com
Thank you,
Old May 20, 2020 | 02:53 PM
Any idea where the fuse might be so I can turn it off until I get my parts?
Old May 20, 2020 | 02:56 PM
Chuck234's Avatar
My guess is in the box in front of the battery. Not sure which one though.
however, I’m sure you have checked to make sure the dash light dimmer switch is not dialed all the way up. It’s the little dial beside the headlight switch. If it’s rolled all the way up. It keeps the interior lights on.
Old May 20, 2020 | 03:25 PM
Thats correct I try everything already but Im going to double check just to be sure.
Old May 20, 2020 | 07:16 PM
disconnect the switches until you find the one thats broken.
