Inside Lights stay ON!
Hello everyone, I really need you guys help with fixing the light issue I'm having inside the door. My inside center light and my inside trunk light stay on and wont come off. My battery already drain once because of this. At this point I just want to at least have it off until I have time to go get it fixed. I have a 2007 hummer h3 (sunroof). I found the fuse box in the engine bay just don't know which fuse it is to for me to remove it so it don't drain my battery. I'm also not sure if theres a fuse box inside the car. Please help so I can remove the fuse so it don't drain my battery. Thank you.
My guess is in the box in front of the battery. Not sure which one though.
however, I’m sure you have checked to make sure the dash light dimmer switch is not dialed all the way up. It’s the little dial beside the headlight switch. If it’s rolled all the way up. It keeps the interior lights on.
