I hope this was the culprit...
Old Aug 21, 2018 | 10:49 AM
Backporch73's Avatar
Default I hope this was the culprit...
Remanufactured??
not terribly bad for 133k Miles looks like someone has already been in here? Hope the cleaning solved my intermittent stalling issue at low speeds.
Old Aug 24, 2018 | 05:52 AM
UPDATE!! Cleaning solved my stalling issue! Thanks Guys!!!
Old Aug 25, 2018 | 01:27 AM
Gomer's Avatar
Good deal. If it happens again there is one more sensor you can clean it’s the on on the top near the rear of engine has a plug going to it. Can’t remember what it is called but i can see it in your 3rd picture in the background. I cleaned mine with some of the left over MAF cleaner and been running great for about 8 or 9 months now.
Old Aug 25, 2018 | 01:31 PM
Thanks! I'll check that out too
Old Aug 25, 2018 | 10:46 PM
Default stalling persists!!
Well the stall seemed to go away for a couple of days but now its back again. I guess Ill start with that other sensor. I also bought some Techron fuel system cleaner, but I have to wait until the tank is near empty. Someone recommended it on the forums in one of my many searches
Old Aug 26, 2018 | 02:31 PM
hummer_on_fumes's Avatar
There's a variety of things that can cause a rough idle but someone here once mentioned trying better gasoline such as shell or exxon instead of Costco or any other "cheap" gas. You may want to try that as well throughout your troubleshooting. The 2 things that made my H3 idle really hard were old spark plugs and then bad valves losing compression. The spark plugs are fairly easy to change but I had to get my valves remachined which cost a good amount
Old Aug 27, 2018 | 09:15 AM
Intake manifold bolts sometimes come loose also.
I5 has a "shake" to it.
Old Aug 27, 2018 | 07:41 PM
BruceS's Avatar
What air filter are you using?
Old Aug 30, 2018 | 05:08 AM
it it just looks like a new generic style air filter, nothing special but it’s clean.
Old Aug 30, 2018 | 07:36 AM
Default Video of almost stalling
Seems worst with the AC on
