Hummer H3 HVAC issue
Old Nov 21, 2019 | 03:21 PM
  #21
TechnoSean's Avatar
Man I am just at a loss. Got the actuators all installed (that mode one was fun to reach). Temp is working fine but mode still goes all the way to defrost if I move one click from head level.
Old Nov 21, 2019 | 03:28 PM
  #22
Did you perform the program procedure?
Old Nov 21, 2019 | 03:44 PM
  #23
TechnoSean's Avatar
I did. Temp far right. Blower far right. Mode far left. Hold defrost and Ac until blinking starts.
Old Nov 22, 2019 | 01:12 PM
  #24
TechnoSean's Avatar
came out last night and calibrated again. Now it’s working. Fingers crossed. Now on to troubleshoot my intermittent “svc Tpm” error.
Old Nov 22, 2019 | 01:29 PM
  #25
Save your old parts, just in case.
Now, did you attempt relearn on the tpms?
Old Nov 22, 2019 | 01:50 PM
  #26
TechnoSean's Avatar
https://www.youtube.com/watch?v=Oa_LcnB5_L0
probably found the problem. Front two won’t learn. Weird that the serv tpm message only pops up sometimes. Taking to my tire place. Thanks again.
Old Nov 22, 2019 | 02:02 PM
  #27
You would do better if you buy 4 ACDelco TPMS and take them with you to the tire store and have them installed. The tire shop will charge you a markup on the sensors and then charge you to install them.
RockAuto has them at the best price and ships quick.
Old Nov 22, 2019 | 02:07 PM
  #28
TechnoSean's Avatar
theyre already replacing the two bad ones. The place is right in front of my neighborhood. $40 each no labor. I just want it done, but thank you for the suggestion. I really do appreciate y’all.
Old Nov 22, 2019 | 02:17 PM
  #29
Chances are there is only 1 that has failed. They should scan them all first. Depending on the age, replace them all when you get a new set of tires.
Old Oct 2, 2023 | 06:38 PM
  #30
handsolo429's Avatar
Default Blend door issue
Hi everyone. Has anyone bern able to fix the blend door issue on an H3 with no heat? Everything works fine even ac and the actuators are turning but i get no heat. How do i access the blend doors?
