Hummer H3 DVD Stereo Install
Old Jul 6, 2014 | 05:07 PM
Mr_Sandman's Avatar
Default Hummer H3 DVD Stereo Install
Finally got around to upgrading my stereo. Install took a little over three hours, complete with device for door chimes. I thought everything was going great, but I do not have the right front speaker or right front tweeter, they are not producing any sound. I pulled the stereo out, there are no loose connections and I did not miss any wires from the harness.
1) What color are the RF speak and RF Tweeter.
2) Is there a fuse that may have been blown?
Want to make sure the wiring diagram I was using was correct. Why would both speakers be having a problem?
2006 Hummer H3 Base.
Old Jul 7, 2014 | 10:05 AM
Mr_Sandman's Avatar
Can anyone help with these questions. Also, can someone provide me with the factory stereo wire diagram for the 2006 Hummer H3 Base. I was using a text document that I am not sure was correct.
Old Jul 7, 2014 | 02:04 PM
citiboy's Avatar
Here's the 2006 H3 complete wiring diagram....see page 90 for the radio.
http://schwarttzy.com/wp-content/upl...iring-2006.pdf
Old Jul 8, 2014 | 09:43 AM
Mr_Sandman's Avatar
From this diagram, it appears that my model does not have an amp? So if I decide to run new speaker wire and change out the speakers and tweeters, 1 to 1, will I have any sound issues? I want to make sure that I will have enough power for aftermarket pioneer tweeters and aftermarket pioneer door speakers. I don't think I missed anything on the stereo installation and I do not believe the RF speaker and RF tweeter is blown. Think this might be the easiest resolution.
Old Jul 8, 2014 | 03:37 PM
The tweet and woofer are NOT wired separate. They use the same channel of the radio. There is a little resistor on the tweet to filter out the low frequencies.
It all depends on the amount of true power you head unit/amp produces and the sensitivity of the components you are installing. It's a complicated formula. Just replace what you have with some low to mid range price speakers and you should be fine.
sjarnold1
22
Apr 23, 2013 04:39 AM
sconnoll
19
Sep 11, 2012 12:35 PM
Alukavi
Mar 19, 2009 07:20 AM
alex00
Sep 13, 2008 03:44 AM
sconnoll
Sep 30, 2006 01:25 PM
