hummer h3 2006 model-cranks, starts & stops
Old Mar 25, 2020 | 01:52 AM
rsrobo's Avatar
Arrow hummer h3 2006 model-cranks, starts & stops
Hummer h3 ,2006 model cranks, starts & stops immediately, no codes or engine light. Anybody experienced the similar problems? any solutions found?
Which is the Best OBD2 PC/Mac software for Hummer fault finding?
Old Mar 25, 2020 | 08:15 PM
try swapping out the fuel pump relay with
another one in the fuse box also look for corrosion "green crusty's"
Old Mar 26, 2020 | 01:12 AM
rsrobo's Avatar
Ignition Coil cylinder no2 was defective, replaced, all cylinder sparks are ok now, swapped the fuel pump relays, no change, fuel pressure is ok around 50 psi steady
Old Mar 26, 2020 | 01:14 AM
rsrobo's Avatar
Thanks, Ignition Coil cylinder no2 was defective, replaced, all cylinder sparks are ok now, swapped the fuel pump relays, no change, fuel pressure is ok around 50 psi steady
Old Mar 26, 2020 | 01:25 AM
rsrobo's Avatar
Best bidirectional OBD2 PC software for Hummers? TOAD? scanTool,net?
https://www.totalcardiagnostics.com/toad
https://www.scantool.net/downloads/diagnostic-software/
Old Mar 26, 2020 | 01:29 PM
Welcome to HF.
MOVED.... all H3 questions go in the H3 Section.
Old Mar 26, 2020 | 07:19 PM
are you getting a padlock on the dash?
Old Mar 26, 2020 | 08:35 PM
wpage's Avatar
You may have a battery issue as well...
Old Mar 27, 2020 | 12:37 AM
rsrobo's Avatar
steady padlock when key on ignition position, vanishes after some time, when cranks, starting & not continuing , it stops.
battery is ok.
what is the best OBD2 PC based software for Hummers?
Old Mar 27, 2020 | 09:47 PM
i purchased a GM tech2 china clone
cowboy1947
Mar 4, 2020 12:56 PM
ajaxisis
Apr 9, 2014 08:54 AM
lgarmik
Oct 16, 2009 07:51 PM
hmcoleap
Jul 6, 2006 12:29 AM
Stubby58
Jun 28, 2006 10:03 PM
