how to reset PCM
Old Oct 14, 2023 | 05:38 PM
Justinh's Avatar
Default how to reset PCM
I've read on this forum that removing power from the PCM is not enough to reset it. So then how is it done? Is it possible to get the adaptive learning values back to default?
Old Oct 14, 2023 | 07:50 PM
Disconnect battery cables, after disconnect, jump in with KOEO, use controls: headlights ON position, turn signals ON position, step on brake pedal so lights are in the ON position, radio/hvac/shifter/door lock/windows etc to drain residual power, take your time and wait until you get to 0.00v.
Old Oct 15, 2023 | 08:10 AM
Justinh's Avatar
0V where, across the battery cables?
Old Oct 15, 2023 | 04:31 PM
0.00v @25
Old Oct 16, 2023 | 07:16 PM
Justinh's Avatar
Thanks.
Old Oct 17, 2023 | 08:58 AM
You cannot "reset" a PCM. You can reboot it, but it will retain the last 300 ignition cycles, power or no power.
The only way to change what is in the PCM flash based memory is to over wright it.
Nray312
Nov 9, 2021 10:40 AM
windycitykid
Apr 9, 2013 08:20 PM
chasekanter
Feb 15, 2011 10:08 AM
jackk frost
Mar 27, 2008 06:56 AM
jbnjc123
19
Mar 1, 2007 01:30 AM
