How do you level the rear?
Old Feb 16, 2011 | 06:07 PM
ElliotF's Avatar
Default How do you level the rear?
Hi Group, I am on my second H3 since 2005. I love the vehicle since I am now on my 3rd retirement. Army, commercial A&D and consulting and fairly **** since I was in engineering.
The question is, how do you level the rear of the H3? I have the front perfect after 5000 miles at 23.5 “, however the rear is an inch off. I.E. 24.75 on the left and 25.75 on the right. I do mark a vertical line on the wheel flair using a level, measuring on a flat surface, from the middle of the H, as well as from the ground up and I am still an inch off on the rear.
Should I just lower the front right or raise the front left to get the rear level, or is there a way to level the rear? I like wrenching, but hate to go to far..
What is more important, front or rear level? Or, just stop being so ****?
TIA, Elliot
Old Feb 16, 2011 | 06:39 PM
drtom's Avatar
Banned
ive heard,here, that they are like that.
if front is level and aligned,ahh what else huh.
hey lucky me ,theres not a level spot on my property! when i park at walmart i just dont look back. no ***** on the back
figger the frame warped?
Old Feb 16, 2011 | 08:34 PM
2wheelmonster's Avatar
I am assuming when you say left you mean the drivers side, if you do mean that then your in luck for an answer, I found this to be the same issue when I leveled mine. Then I realized that the gas tank is on the drivers side. Many could argue that it has nothing to do with it, but one gallon of liquid supposdly weighs eight pounds. So with that said stop be so **** about it and run it.
Old Feb 17, 2011 | 09:09 AM
ElliotF's Avatar
Thank guys, I do just run it and I will stop looking at it. After the reply about gas, I checked it again on the same spot and with my tank being 1/4th down from yesterday, I have gained 1/4" on the left rear. I will wait until almost emply and take another measurement.
Thanks again, Elliot
Old Feb 17, 2011 | 11:01 AM
Hunner's Avatar
Talking
Load up some tools and spare parts and it will come down!
Old Feb 17, 2011 | 02:22 PM
There was an old TSB on this very topic. Do a search here, we hashed it in several threads.
Nut shell: Losen the shackle bolts for the rear, get a couple friends to play bumper monkey or drive it down your street slowly and swerve back and forth to free free up the leafs at the shackles, then measure, and retorque.
Old Feb 17, 2011 | 07:39 PM
ElliotF's Avatar
Wow, thanks Doc. I will give it a shot..
jsbihn
Jan 6, 2015 10:48 PM
Maxx
May 31, 2014 10:40 PM
hummer1
Mar 9, 2007 04:26 PM
HummerGuy
Oct 19, 2006 01:26 PM
REDLYNER
Sep 13, 2006 05:11 PM
