High Side AC Fitting Leaking
Old Jun 17, 2020 | 06:10 PM
rmach3's Avatar
Default High Side AC Fitting Leaking
Can someone post a pic of the high side AC fitting for a Hummer H3 (2007)?
Dealer told me it was leaking. If you feel that this an easy fix, would be appreciate if you share how you went about doing this.
Thank you!
Old Jun 20, 2020 | 07:33 AM
ski.dive's Avatar
Old Jun 20, 2020 | 02:13 PM
A/C leaks are simple/cheap, usually an o-ring seal or schrader valve replacement, to stop the leak. You will need a recover/recharge machine to perform the repair yourself.
Old Jun 21, 2020 | 10:21 AM
rmach3's Avatar
Ski.divd and Hummerz, thanks for sharing. Since I don't have access to a recover / recharge machine, this does not seem to be a task I can take on myself. Appreciate the info.
Old Jun 22, 2020 | 11:31 AM
ski.dive's Avatar
You will need replace the valve and add a can and a half of Freon.
Here is the HP side valve you need
03H2BlackBetty
Sep 18, 2018 12:09 PM
jmH3
Aug 21, 2017 09:17 AM
mp51998
May 9, 2016 11:47 AM
jsbihn
Jun 16, 2015 08:58 AM
jsbihn
May 7, 2015 08:01 AM
