Help me decide which fan clutch to buy for H3 2007
Old Jun 2, 2013 | 07:24 AM
Alex2012's Avatar
Default Help me decide which fan clutch to buy for H3 2007
Hi there i am running bad on my H3 fan clutch as its not engaging fully any more the ac is of and i see the heat gauge goes to 3/4 or a bit more then the 3 mark
VIN: 5GTDN13E478184220
Year: 2007
Make: Hummer
Model: H3 Base / H3x
at around 98K miles
i go often off road and i found the fact there is 3 types of fan clutch on net
Standard vs. Heavy vs. Severe Duty
i need to buy severe duty fan clutch please help me find the exact fit product for my H3
here is a link to rock auto
2007 HUMMER H3 Radiator Fan Clutch
which one you think is better for off road and low speed mountain climbing?
i found this one on amazon
Evan-Fischer EVA12672036335 Fan Clutch Severe-duty thermal : Amazon.com : Automotive Evan-Fischer EVA12672036335 Fan Clutch Severe-duty thermal : Amazon.com : Automotive
please help me decide which one to buy and guarantee to fit my H3 with the vin given thanks and regards.
Old Jun 2, 2013 | 08:23 AM
sneakypigeons's Avatar
any of them will do. If rock auto says it will fit then it most likely will, i've never had any problems with the parts i ordered from them. try also this...06 2006 Hummer H3 Fan Clutch - Cooling System - Hayden - PartsGeek.
I ordered this same one... i havnt installed it yet tho. shipping from this company is only $8.95.
Old Jun 2, 2013 | 02:52 PM
skeeter's Avatar
if you can afford it, I would just go with an electric fan.
Old Jun 2, 2013 | 06:21 PM
My gauge runs max 1/2 no matter what the temp is outside! No reason to add an air flow obstruction/voltage usage device(aka:electric fan)! Replace the clutch, upgrade if necessary, or install a "flex flan" if needed, to keep that temp down.
Old Jun 2, 2013 | 07:04 PM
Alex2012's Avatar
thanks for the link bro
Old Jun 2, 2013 | 07:06 PM
Alex2012's Avatar
thanks i don't have money to upgrade it right now i already done many modification and upgrades may be later thanks for the helpfull information
Old Jun 2, 2013 | 07:12 PM
Alex2012's Avatar
i just ordered the HAYDEN Part # 2787 Thermal Reverse Rotation Severe Duty Thermal Fan Clutch
hope it be same rotation direction as my my original fan clutch numbered
part 25948772
here is my car
Old Jun 2, 2013 | 07:44 PM
Happy Hummer's Avatar
Nice...looks good.
Chris
Old Jun 2, 2013 | 09:48 PM
skeeter's Avatar
I just know that there is not a lot of room to work with in there. I would just get rid of the fan and clutch for an electric fan for the extra space.
Old Jun 3, 2013 | 11:52 AM
Has anybody ever tried one of these flex fans with a late model GM clutch fan truck? I can tell you they will make noise, a bunch of it, all the time non-stop.
I have been running an Efan conversion for 2+ years, solid performance and MPG boost. Never ever come on late fall through early spring.
