Help to identify this part
Old Aug 21, 2013 | 06:26 AM
eleewhm's Avatar
Originally Posted by Bunger
Man1 - the upper mounts are solid rubber. They aren't going to go bad for a very long time. The lower isolators are a thin walled rubber donut with a steel disc bonded to it. The rubber is usually fine, it's the steel part that rusts and detaches from the rubber.
eleewhm - All of the bolts are the same length, should be no need to trash the old bolt either, they are galvanized grade 10.5 and should be fine once you get them out. They are Flange Bolts and have a special rounded tip that helps to line everything up as you put it back in.
If you really want to get new bolts, they are about 5" long (whatever the metric equiv. is) and need to be 10.5 grade (grade 8 might be OK). But be prepared to pay close to $10 per bolt.
Your choice but I would reuse the old ones.
thanks bunger.. i would see if i can remove the bolt and reuse then.. as the bottom isolators fell off...
Old Aug 30, 2013 | 10:59 PM
KTM640Dakar's Avatar
If the lower rubbers are still hanging on then just add a washer under the nut where the rusted one was.
mullynyc
Sep 7, 2012 08:22 AM
FBINA234
Jun 3, 2012 11:06 AM
m561gamagoat
Apr 26, 2011 10:38 PM
markushp
Oct 13, 2009 10:25 PM
Father Todd
Feb 25, 2008 10:26 AM
