Help. 06 H3 a/c head unit lights dont turn on and blowing hot air
Old Jul 25, 2014 | 10:07 AM
amplango1's Avatar
Default Help. 06 H3 a/c head unit lights dont turn on and blowing hot air
I have a 06 Hummer H3 3.5L. I put in an aftermarket radio and was trying to put in a relay to bypass the parking brake so I can use my pioneer appRadio mode. I didn’t not take the positive wire off the battery. When hooking up positive wire ( Orange ) from factory wire harness it touched the negative wire and saw a little spark. After that I had no power from the orang wire. So I went and looked under the hood and checked fuse #13 and it wasn’t blown. I checked all fuses and all where good. No blown fuses. I hooked up a direct line from Battery Positive with 10 amp fuse to radio. My radio works great, Now, Here is the real problem I’m having. Now keep in mind, The Power to the radio ( orange ) wire still has no power. I turn my A/C on and it blows out hot air. The orang light that goes on when you push the head unit to turn on A/C cool air doesn’t light up and the compressor doesn’t turn on. None of the ( orang ) lights turn on when I push the A/C head unit. My A/C blower works just fine. So I check All the relays and there fine. I checked the diodes and all is good. I unplugged all the connectors on the head unit and plugged them back in incase something came loss. Still, No cool air and no lights ( orang ) turn on. So does anyone have a clue on what might be the problem might be?
Old Jul 25, 2014 | 05:23 PM
happythree's Avatar
og wire fuse 38, 25 amp,,,look again and read volts on both sides of it.
its radio only,not air?
Old Jul 25, 2014 | 08:10 PM
Happy Hummer's Avatar
I was honestly lost reading this.
Chris
Ac works?
Ac don't work?
Radio works?
Radio don't work?
How about take the radio out of the equation and just describe problem.
Chris
Old Jul 26, 2014 | 07:57 AM
happythree's Avatar
yeah,i didnt look close enuf. theres a lot of "og" wires!
recheck the fuse. and clutch fuse 48
H2_UK
Jul 19, 2018 09:03 PM
Tram
Jul 21, 2011 12:08 PM
lpelletier
Jan 20, 2011 03:24 PM
FLCHRIS
Nov 6, 2009 11:04 AM
HummBob
25
Sep 27, 2008 08:23 PM
