Hard stall in closed loop
Old Dec 17, 2019 | 10:31 PM
H3steve's Avatar
Default Hard stall in closed loop
I got this new to me 06 3.5l 150,000miles
The truck is starting fine and runs in open loop but has a hard stall in closed loop, like I turned the ignition off stall, no hickup or stuttering. This stall is at idle and I cannot drive it once is stalls , I have to wait for it to cool/ go into open loop.
If i disconnect the MAF it will not stall.
I'm thinking this is a PCM issue but not for sure, I would appreciate any insight that y'all may have.
Old Dec 17, 2019 | 10:42 PM
Clean the MAF.
Old Dec 17, 2019 | 10:56 PM
H3steve's Avatar
Clean the MAF.
I cleaned the original MAF and when it didn't help replaced it with a new acdelco MAF just to be certain.
Please let me know what other info you need for input. The truck got a full tuneup I'm really at a loss except for a vvt or pcm issue
​​​i am reaching my diagnostic limits and would very much appreciate some help
Old Dec 17, 2019 | 11:20 PM
how long will it run without the MAF connected? what temps are you seeing on intake and engine.
Old Dec 17, 2019 | 11:34 PM
H3steve's Avatar
​​​​​​It seems to run at idle indefinitely with MAF disconnected. I did not try to put it on the road
I'm not sure exactly what your asking of intake. Ambient temperature is 60f. I got 217f engine temp on the scanner, I could see the thermostat regulating the temp some . Please explain this more
Old Dec 17, 2019 | 11:39 PM
Clean the MAF connector. Btw, post the codes.
Old Dec 17, 2019 | 11:44 PM
Old Dec 17, 2019 | 11:45 PM
H3steve's Avatar
I will reclean the connector tomorrow, as of now there are no codes .
I will update after cleaning
Thank you so very much!
Old Dec 17, 2019 | 11:56 PM
H3steve's Avatar
​​​​​​I don't understand, from what I can tell normal operating temps are 195f to 220f
I got 117f from the OBD2 .
am I missing something?
Old Dec 18, 2019 | 12:11 PM
what do you mean by ambient air temperature at 60?
the MAF sensor has an intake temperature sensor what temp does the scanner read for that sensor.
zenoreilly
Nov 15, 2019 07:55 PM
H3steve
Oct 15, 2019 10:28 PM
user 956363738
24
Jan 4, 2017 07:11 PM
Knightblade
Sep 26, 2016 09:28 AM
Justinh
Jan 9, 2016 11:18 AM
