H3 vibration above 55-60mph
Old 01-15-2013, 10:28 PM
Brodie's Avatar
Default H3 vibration above 55-60mph
Hey All,
I took the rig in to have both axle seals replaced by the dealer and the transmission flush service. After picking up the vehicle and getting up to highway speeds I felt a bad front end vibe and to the point where it was noticeably shaking the steering wheel. I took it back to the dealer and they said nothing was loose but I needed new tires. Mind you this wasn't happening before I brought it in for the initial repairs.
I'm just wondering what it could be if nothing's loose? Maybe they installed the shafts back incorrectly? The seals aren't set right? I had the front end realigned after they did the repairs and still notice the vibe. Thanks
Old 01-15-2013, 11:52 PM
Check to see if they knocked off a wheel weight or 2 when they removed and reinstalled the rims/tires. There should be a slight mark in the rim where a weight would have been.
Old 01-16-2013, 07:52 AM
Stating the obvious, but look to make sure all lug nuts are in place. I had a tire shop strip a lock nut years back, rather than tell me, they just left it off. One missing lug nut creates a bunch of vibration.
Old 01-16-2013, 08:40 PM
Happy Hummer's Avatar
Agree. It makes a lot of racket and vib's.
Chris
Old 01-17-2013, 05:42 AM
sublmnl's Avatar
If your tires are worn some esp. from not being aglined properly if they re-installed the front tires on the opposite sides it could possibly cause some vibs too.
The wheel weights would be my first guess.
jaymazurk
03-21-2014 04:43 PM
Alex E Art
37
10-09-2007 04:43 PM
Bennersj
09-01-2007 07:49 AM
REDLYNER
09-13-2006 05:11 PM
SublimeHummer
04-06-2006 12:06 PM
Quick Reply: H3 vibration above 55-60mph
