H3 Transfer Case - BW 4494 (4:1 Low)
Old Nov 28, 2008 | 05:58 PM
mattroanai's Avatar
Default H3 Transfer Case - BW 4494 (4:1 Low)
As I stated in my introduction, I spent several years as a technician for a major transfer case manufacturer. With that said, I often pick up good cores when they become available and go through them to be sure that the internals are okay and then re-sell them in order to make some side money. All of the replacement parts used are factory GM pieces....not some aftermarket items.
Right now I have a BW4494 transfer case that came from a 2006 Hummer H3 with just over 12k miles on it. The unit would not shift out of 4HI Lock. Upon teardown, the mode fork (OEM plastic) was found to be the culprit. I replaced the mode fork with the new improved GM service replacement design (aluminum) along with the mode collar and drive sprocket bushing. All of the other components were thoroughly inspected and cleaned prior to reassembly. Please note however that one of the wire leads for the actuator is slightly chafed - an easy repair with some shrink tube - but I did not repair this item as I intended to leave it up to the buyer.
This is a great replacement part to have on hand for those of you who like to go off-roading and would be a great upgrade (4.10:1 4LO ratio) for those of you who have the standard BW4493 with the standard 2.64:1 4LO ratio.
Asking $700 OBO.
Old Dec 1, 2008 | 12:34 PM
mattroanai's Avatar
Default RE: H3 Transfer Case - BW 4494 (4:1 Low) - PRICE REDUCED!
Just a shameless bump to the top and a price reduction also. Now asking $500 OBO.
Old Apr 24, 2009 | 07:06 PM
darrellbm's Avatar
do you still have the bw4494,if so,what's your best offer and where r u ocated-thanks-darrell
Old Apr 24, 2009 | 07:07 PM
darrellbm's Avatar
do you still have the bw4494,if so what will you take,and where r u located-thanks,darrell
Old Dec 21, 2009 | 12:16 PM
deleaur's Avatar
Default 4494 transfer case (4:1 low)
Mattroanai
Do you still have this 4494 transfer case (4:1 low)? If so were are you located? can yo give me a number?
thanks
Bob
Old Dec 22, 2009 | 08:37 AM
darrellbm's Avatar
Default 4494 t/case
yes,I have 4494's and also have 4493 ,and 4484 too.I need the 4494-007,008,etc.That is borg warner's assembly #,if you will check that before calling me,(it's on the bar code on the top of the t/case).I aquired several of each when gm auctioned off a lot of borg warner stuff,and I will be happy to service any transfer case needs,and provide a warranty.If you call me and I can't answer,please leave a callback #,the assembly # and I will call back asap.I'm in Tallahassee Florida.My # is 850-556-9055.Thanks,Darrell
Old Jan 30, 2018 | 01:24 PM
ynot44444's Avatar
It's a long shot but are you still selling cases?
Old Jan 31, 2018 | 10:18 AM
Really, from 2009? 9 years ago, really?
Old Jan 31, 2018 | 12:32 PM
ynot44444's Avatar
Yes really...Like I said...Long-shot...lol...and he lives near my area.
Old Jan 31, 2018 | 07:28 PM
mattroanai Last Activity: 12-12-2008 10:35 PM
