H3 Performance Intake Systems
Old Mar 10, 2008 | 05:11 PM
jackk frost's Avatar
Default RE: H3 Hummer Perormance Intakes Systems
nice doc please PM me or let me and I will give you my e-mail I want notified as soon as u have an 08 kit avalible. I will be buying form you.
Old Mar 10, 2008 | 06:14 PM
Will do Jacck, no worries. As soon as there is a filter for the 08s I intend to let them fly!! You're on the list.
Old Mar 10, 2008 | 07:05 PM
08ALPHA's Avatar
Doc, put me on the list, I'm sure the Alpha could benefit from it.
Old Mar 10, 2008 | 07:49 PM
doc will you pleasesell the kit with the filters? To be honest I don't wanna deal with having to get the filter seperate and would be willing to pay a few extra bucks for you to you to include in the kit since I am lazy. Look at it like this you can make a few bucks off of the filter too. I vote for the K&N's myself
Also I am serious about you e-mailing me when the kit is ready don't worry about approching me I have already decided on your product! I know quality and you do good work from the pics I have see. I used to do allot of welding/metal work and this is quality
Old Mar 10, 2008 | 07:57 PM
Congrats Doc. Looks like a very warm welcome.
Old Mar 10, 2008 | 08:39 PM
08Alpha, you are added to the list.
Jackk, we will work it out when a filter is released. I'll be glad to help. Thanks for the compliment, I have a sweet welder and a shop equipped
to make anything.
That is why I started AirDocIntakes.com, I have made custom stuff for myself over the years, then I might make a couple for a few friends,
show goers, some bruds in trade for other stuff. My friend Kevin said these pipes are too cool not to offer them for sale with the parts I sourced
to make a kit.
However, I don't look forward to being in the grinding room cutting steel, or up close and personal with my welder when it's beautiful weather
in July. [&o]
More Hummer stuff on the way, such as UBP and guarding like you have never seen before, just check back time to time.
Old Mar 10, 2008 | 09:44 PM
ALPHA XY's Avatar
awesome doc...as soon as the ALPHA one is ready, let me know you have a sale!
Old Mar 10, 2008 | 09:52 PM
Will do Alpha XY, and thanks. Thanks to everybody here at the forums for your support.
Old Mar 11, 2008 | 02:25 AM
Gunner_45's Avatar
Well, well, well……………..I guess the cat is out of the bag now.
OK fellas, I too have been testing one of these bad boys for Doc over the past few weeks and all I can say is “Sweeeet”.
Quality:
Only the best materials appear to have been used. Fit and finish are excellent.
T-bar clamps are overkill. But they are in keeping with the “built right” approach to this kit
and quite frankly, just look right on a Hummer.
Installation:
Very simple, 30-minute process.
Instructions are lengthy, but that is necessary to accommodate the novice.
Regardless of your experience level, I highly recommend that you read them prior to the install.
Note1: Removing the snorkel from the breather box is a bit of a pain and might require some to use a second set of hands.
Note2: Proper placement of the new snorkel between the breather box and the fender well CAN be a bit tricky. I took me a
couple of tries to get it “just right”, but it went in as advertised and fit quite well. Once anchored with the supplied
screw, everything is just as rigid as stock with an even better seal.
Performance:
I experienced a bit of rough idle upon initial startup but that went away shortly after the engine got up to normal operating temperature.
Also, it seems like it takes the computer a little time to figure out what to do with all the extra air and get itself dialed in properly.
Improvements are immediately noticeable. Increased power and torque seem to be from 2000 RPM and up. The power band seems
a lot smoother now and the shift points come a LOT quicker....
Expect post install MPG to really bring thesuck on your first tank of gas, cause YOU WILL NOT BE ABLE TO KEEP YOUR FOOT OUT OF IT.
Subsequent tanks should fare better and once I finish tank number four, I’ll post up my MPG figures.
Air temps at the intake manifold are within a few degrees of ambient at highway speeds.
Noise:
No rattles, no buzzing. You will however notice a bit more “throaty” sound during you’re uhhhhh……. “exhibitions of acceleration”
Is it a V8? No. Is it a SC? No. Is it a Turbo? No.
Quite simply, It is a performance mod for an I5 that gets you A LOT of BANG for THE BUCK.
Great Job Doc and good luck with future sales. I really appreciate your efforts in putting this kit together.
Suggestions:
Offer it unfinished for those folks that want to color match the tube to their body color.
An extra .5 to 1.0 inches of length on the snorkel tube would be ideal in future versions.
Oh and a few pics…….
Before:
After:
Old Mar 11, 2008 | 07:13 AM
HummerGuy's Avatar
I told Doc about the snorkel also.
