H3 Performance Intake Systems
Old May 24, 2008 | 08:53 AM
  #181
VTCanyon06's Avatar
Default RE: H3 Hummer Performance Intakes Systems
That is one wierd looking filter on the 08's
The Fram Air Hog filter (PRA9778) for up to '07 is currently on sale at Amazon for $24.99 - $20 rebate = $4.99
Old May 24, 2008 | 05:17 PM
  #182
rhill20's Avatar
Doc, wifey needs one when you are ready for the 08's! Even with the stock filter it would be better!
Old May 24, 2008 | 05:21 PM
  #183
rhill20's Avatar
I just emailed a family friend that works directly for Airaid (where I got my filter/TBS for the 07) about new filters for the 08's. Will let you know what comes out of it. He works directly with the R&D dept in AZ.
Old Jun 1, 2008 | 11:15 AM
  #184
motley1987's Avatar
Until an aftermarket filter is ready for the 08's, since one of the main problems seems to be the MAF sensor, couldn't I just cut the tube leading from the air box cover to the MAF sensor (cut it close to the cover ) and use a hose clamp to attach the new CAI? Then I wouldn't need an adaptor for the MAF sensor since they're more trouble than they're worth to get them to fit. I'm thinking this would be a temporary fix until the air doc is ready but I don't know.
Old Jun 1, 2008 | 11:18 AM
  #185
Muddydawg75's Avatar
It might work... but Doc has strived to make a product that can be removed and your intakereturned to stock at any time....
Old Jun 1, 2008 | 11:22 AM
  #186
motley1987's Avatar
I'm definitely going to get one of Doc's when they're available, but my impatience always gets the better of me.
Old Jun 1, 2008 | 11:38 AM
  #187
Old Jun 4, 2008 | 02:54 PM
  #188
veves's Avatar
I was thinking of useing the bootleg Spectre maf convertor. Its a 3" pipe.
Old Jun 5, 2008 | 07:54 AM
  #189
Might work? I just don't recommend cutting up the stock intake, but your idea might work. Sure wish somebody would come out with a performance filter. [&o]
Old Jun 5, 2008 | 08:18 AM
  #190
motley1987's Avatar
I got the Spectre adaptor but I had to use a Dremel to open the hole wide enough to fit the sensor since it's so wide. Once I did that, there's not a tight seal when I put the sensor in. By the time I'm done tinkering with it, it's going to be an ugly mess that may not even work. So I'm hoping a performance filter comes out soon.
