H3 horn fix...
Old Jul 5, 2022 | 08:42 AM
cooter's Avatar
From: Placitas, New Mexico...Not really New and not Really Mexico
Default H3 horn fix...
If you're tired of the H3 toot. I'll tell you what I did to fix it. got a twin horn from a 2010 GMC Sierra 3/4 ton. GM part # 84501930. Plugs right in to my 2009 harness. I used the stock bracket, took off the single horn, and attached the horn assembly. Everything clears the grille and now it sounds like a truck.
Old Jul 5, 2022 | 08:54 AM
On my 07 I used a Deluxe 4 Horn set from a 1971 Cadillac Eldorado.
Thanks for the tip with PN for a Horn Replacement.
Old Jul 5, 2022 | 12:12 PM
650Hawk's Avatar
Yeah, I've heard the Cadillac Eldorado horns are the bomb!
Old Oct 26, 2022 | 10:36 AM
Mammoth H3's Avatar
Thanks for the info. My stock horn is useless I was looking around for something else. Mine is an 07 so I'm sure the plug will be the same. Would you have a picture of them installed my any chance?
Old Nov 12, 2022 | 05:46 PM
Mammoth H3's Avatar
Cooter... Thanks again for the info. I did the install today. I ordered the horns from Amazon. The sound the new horns make is a huge upgrade the H3 should of came with them from the factory, not sure what someone was thinking adding that one small sounding horn.
As you can see I used the factory bracket to install the new horns on only needed to add a new bolt/nut and washers to hold them on.
dbruno94
Oct 28, 2013 11:34 AM
Asanti
Oct 21, 2011 11:17 AM
finall
Mar 13, 2010 06:11 AM
Wrongway1
44
Nov 14, 2007 10:13 PM
Hummergirl4
May 5, 2007 02:42 AM
