H3 Headlight wiring diagram
Old Mar 13, 2007 | 08:28 PM
Dennis C's Avatar
Default H3 Headlight wiring diagram
I am currently attempting to install an HID headlight kit in my 2006 Hummer H3. The kit plugs into the existing headlight plug with "wire spades". The directions call for one to go to GND, one to HIGH BEAM and one to LOW BEAM. The directions don't say which is which. There is a blue wire, a pink wire and an orange wire.
Does anybody know which is which or have a diagram?
Thanks very much for your help.
Old Mar 13, 2007 | 08:58 PM
Little Monster's Avatar
Default RE: H3 Headlight wiring diagram
There are many post for this subject use the search tool at the bottom of the forum page...good luck
Old Mar 14, 2007 | 12:46 AM
importkiller's Avatar
yup, do a search under my name as author, I posted the color codes a few times already.
Old Mar 14, 2007 | 02:18 PM
Dennis C's Avatar
Thanks for the help.
I found importkiller'spost from January that indicates the following:
Orange = low beam
Blue = ground
Violet/pink = high beam
This is a kit that hasxenon low beams and halogen high beams. I'll install it this weekend and let you know how it goes. If the kit works with the DRLs, I'll probably leave them active. If it flickers or has other trouble due to the reduced voltage to the headlights for DRL, I'll pull the fuse.
Thanks again,
Old Mar 14, 2007 | 07:05 PM
hummana's Avatar
which site did u buy the kit....can u provide it? and how much?
crank
24
Oct 17, 2013 05:21 AM
littlehummerboy
May 14, 2013 05:17 PM
H34me
Dec 8, 2007 10:15 AM
96TL
16
Oct 10, 2007 01:20 AM
2L8IWON
Apr 26, 2007 04:37 PM
