H3 Headlight wiring diagram
I am currently attempting to install an HID headlight kit in my 2006 Hummer H3. The kit plugs into the existing headlight plug with "wire spades". The directions call for one to go to GND, one to HIGH BEAM and one to LOW BEAM. The directions don't say which is which. There is a blue wire, a pink wire and an orange wire.
Does anybody know which is which or have a diagram? Thanks very much for your help. |
RE: H3 Headlight wiring diagram
There are many post for this subject use the search tool at the bottom of the forum page...good luck
yup, do a search under my name as author, I posted the color codes a few times already.
Thanks for the help.
I found importkiller'spost from January that indicates the following: Orange = low beam Blue = ground Violet/pink = high beam This is a kit that hasxenon low beams and halogen high beams. I'll install it this weekend and let you know how it goes. If the kit works with the DRLs, I'll probably leave them active. If it flickers or has other trouble due to the reduced voltage to the headlights for DRL, I'll pull the fuse. Thanks again, |
which site did u buy the kit....can u provide it? and how much?
