H3 Cracked Door Check
Old Mar 20, 2021 | 02:26 PM
KU1525's Avatar
Default H3 Cracked Door Check
The driver's side door on my 2008 H3 recently started making a grinding noise once it hit a certain point when opening and closing. Looked at it a few different times, sprayed some WD-40, but then finally saw that the end of the door check that's attached to the body (not the end that goes into the door) is cracked and entirely separated. Posted a pic of the crack below Does anyone have experience with replacing the entire piece? Looks like it's just two bolts but you have to remove the entire door panel to thread the hinge end through the door frame. And also, I'm not sure which door check to even buy for my 2008. GMPartsDirect says it does not fit but the same part number on wholesalegmparts says it does fit.
Can anyone confirm the GM part number for the 2008 model? This is what I've found:
GMPartsDirect: Door Check - GM (15929238) DOES NOT FIT 08 https://www.gmpartsdirect.com/oem-pa...check-15929238
WholesaleGMParts: Part Number: (15929238) DOES FIT 08 https://www.wholesalegmpartsonline.c.../15929238.html
broken door check at hinge
Overdriven6
Aug 10, 2023 10:33 AM
Draketh
May 25, 2011 08:44 PM
lets get dirty
19
Jul 4, 2009 03:32 PM
HummerDriver
Jul 11, 2007 04:53 AM
H1OFAZ
Jan 13, 2007 07:05 PM
