H3 Clear Lens' for Roof Marker Lights
I havent been able to find them.. i went ahead and actually used the VHT Nite shade paint.. here is a pic below... ill try and get more for you with the lights pon and full pic of truck with them on...... i found that the cab lights are no longer available AT ALL inn Amber or any other way ( clear or smoked)
BEFORE TINTING LIGHTS
AFTER PIC
thanks.. took me about 2 hrs from start to finish and they came out very smooth.. i suggest if anyone uses the VHT niteshades to use MAX 2 coats.. thats what I used. also for those very picky i would after clearing them to use 3000 grip sand paper and wet sand them and then hit it with a little more clear ...2 coats... and should look like glass.. ill be sending a few more pics later .. waiting on some side vents and i also purchased the clear led side marker and parking lights..
but i think the blacked out look is good.. better then the ambers...
Horned Frog
07-26-2011 01:54 PM
