H3 chassis package type?
Old Apr 10, 2025 | 11:02 AM
AZ_H3!'s Avatar
Default H3 chassis package type?
How can I tell which chassis package my H3 has? The Z85 increased capacity or the ZM6 off road package? Are rear axle assemblies interchangeable between the two packages?
Old Apr 10, 2025 | 11:24 AM
Glove box will have the RPO codes youare looking for.
If the glove box door was replaced the Adventure/Offroad package is easy to identify by a 285/75R16 size tire on driver door B-pillar.
The standard Z85 heavy-duty handling and trailering suspension was on non Adventure/Offroad packages.
Old Apr 10, 2025 | 01:36 PM
Welcome to HF.
What year is yours?
All the rear axles themselves are the same: I5s have 4:56 gears, the 2008+ Alphas have 4:10 gears. Z85 had nothing to do with axles per se, except we know the Z85 did NOT have an Elocker. The Adventure/Offroad package has a small hole in the top for the electrical wire for the rear locker to run through. The axle capacity is the same.
Z85 was a GM bs lingo way of saying you got something special even though you do not have a rear locker or the off road suspension = you got the base level special stuff.
Old Apr 10, 2025 | 02:00 PM
AZ_H3!'s Avatar
It's a 2006 and Im looking to get the rear axle assembly rebuilt or replaced and used assemblies tend to specify either ZM6 or Z85 so I didn't want to get one that didn't work.
Old Apr 10, 2025 | 04:56 PM
wpage's Avatar
Like Doc said the rears are all the same so you should have now questions on which way to go with the 06 rear...
Old Apr 11, 2025 | 10:39 AM
Just find any H3 2006-2010 rear axle without locker from any I5 (3.5 or 3.7L) donor truck. You do have an opportunity to upgrade to a rear locker if that is important to you.
Or, if you have a local rear end/differential specialty shop, they can rebuild it with all ne internals fresh as a daisy. Not a cheap service these days.
Old Apr 12, 2025 | 12:26 AM
AZ_H3!'s Avatar
Thanks to those for answering my post.
adventurous
23
Jan 5, 2009 07:01 PM
Zipthelipp
Dec 1, 2008 05:05 PM
millerb7
Sep 24, 2007 04:02 PM
mjh
Aug 23, 2007 09:46 AM
melvynray
17
Nov 5, 2006 12:55 AM
