H3 3.7 thrown rod
Old Aug 19, 2020 | 09:54 PM
maximoxxdi's Avatar
Default H3 3.7 thrown rod
So about two days ago I was just getting on the main road less than a mile from my house and all of a sudden I hear a very loud clunk and the truck started vibrating violently. When I pulled over I saw the oil leaking and realized I had just blown the engine. It seems to have thrown a rod which made a hole in the side of the block (see picture) and made a mess of the oil! I have a few questions that maybe you guys could help with.
Is this common because it only has 65k miles?
Is it best to find a used one or rebuilt? ( I plan on doing the work myself and I plan to keep it for a long time)
Depending on the question above, where is the best place to find an engine?
Lastly, is there anything particularly tricky about removing the engine from the H3?
Thanks, I really hope that I can get this done without too many issues!
Hole in the Block
Old Aug 20, 2020 | 10:26 AM
No it is not common at any miles.
Stick with the same year I5 if you can find one and the swap will be easier. Used & rebuilt can both be a crap shoot, rebuilds are in short supply.
Good luck.
Old Aug 20, 2020 | 04:17 PM
Happy Hummer's Avatar
Wow, that was aired out quickly. the is pretty wild. I'd be interested to know what gave way first? Tear it down and do rebuild with a replacement block.
Old Aug 20, 2020 | 04:36 PM
if you just got it take it back. let them sort it out or refund your money.
Old Aug 20, 2020 | 05:36 PM
maximoxxdi's Avatar
I just ordered a reman engine from Jasper engines, it was the last one they had in stock and it is supposed to arrive this upcoming Monday. When I removed the skid plate under the engine I found the part of the block that had broken along with remains of two broken screws that seem to be from the connecting rod (picture below). I have never seen this happen to a stock motor that has no form of forced induction, I wonder if there was maybe a defect in the metals?
Old Aug 20, 2020 | 05:39 PM
what year h3 is it?
Old Aug 20, 2020 | 05:40 PM
maximoxxdi's Avatar
It is a 2009
Old Aug 20, 2020 | 06:56 PM
Whoever went in forgot to properly torque the crankshaft main bearing cap bolts. Scrap the engine and start over, although the head should still be good. Just order a short block, and you will have to pay for the core charge, since yours is Fvcked.
Old Aug 27, 2020 | 12:31 PM
maximoxxdi's Avatar
I finally got the engine out and the new one in, hopefully I'll be done by this weekend!
Old engine coming out
Another hole that I had not seen before
The original hole
New engine in
Old Aug 27, 2020 | 03:26 PM
H3Luxembourg's Avatar
Damn good job done man, hope all is doing fine at first start.
